Is it ok to keep on disconnecting my main relay as an antitheft precaution
Re: Is it ok to keep on disconnecting my main relay as an antitheft precaution (pumpkyn)
Yes it's ok, nothing to worry about. But why not a switch instead? a hidden switch makes it a little bit more comfortable... I know the feeling of not really knowing something and wondering if it's ok or not, but it is trust me.
Re: Is it ok to keep on disconnecting my main relay as an antitheft precaution (fast95eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 »</TD></TR><TR><TD CLASS="quote">Yes it's ok, nothing to worry about. But why not a switch instead? a hidden switch makes it a little bit more comfortable... I know the feeling of not really knowing something and wondering if it's ok or not, but it is trust me. </TD></TR></TABLE>
im going to install swtiches as well now that i converted my car to manual i know people are going to want it in my neighborhood, im also going to install a hood lcok
Re: Is it ok to keep on disconnecting my main relay as an antitheft precaution (schlit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit »</TD></TR><TR><TD CLASS="quote">Other than the fact the connector wasnt designed to be taken on and off on a daily basis, I dont see how it would hurt anything. You may end up getting loose connections or something.</TD></TR></TABLE>
thanks
thanks
you don't want to be disconnecting that all the time. eventually you will break something or wear it out... and you don't want your main relay to die on you on your way to work or something.
1.) Install a switch .
2.) install an alarm
and check out these links
https://honda-tech.com/zerothread/1194912
https://honda-tech.com/zerothread/1669873
Re: Is it ok to keep on disconnecting my main relay as an antitheft precaution (Crazydave)
There was another write up on how to theft-proof a civic, but I can't find it right now..
it talked about how to protect your civic from being slimjimed, to installing remote batteries and alarms and all kinds of good things...
fuel pump switches iginition kills,, etc.
4DRmafia
11-09-2006 09:48 PM
mrdeadman
Audio / Security / Video
09-23-2006 08:52 AM
a1320addict
02-08-2006 09:59 AM
