Two questions. Friend wantrs to drop 92-95 LS in 96 Hatch whats needed.
I have a friend that is going to drop in a 92-95 LS motor in the 96 Civic. What is all needed? Also since the motor is older than the car buy a few years is it able to smog in California?
I told them to get all mounts from a ls out of a 96+ integra and they should be set... Or is my info incorrect?
So the mounts need to be of a 96+ intgera so it will be a direct drop in their 96 dx. Also will the model be smog legal in california?
Re: (1baddc5)
its EMISSIONS and thats the same as smog.....and no the 92-95 doesnt apply to the LS...90-01 does but if the engine is older than the car you cannot pass emmisions... and the mounts wont aork you need 99-00 si civic mounts (i think i dont like EK's)
Re: (CBEengineering)
well excuse me genius i spelled it wrong wasnt thinkin best thing to do it just buy you mounts from hasport or ive heard that you can get them form jegs cheaper than anywhere or ebay but i dunno if i would trust ebay or not
99-00 SI drive side motor mount bracket
99-00 Rear "L" bracket
everything else from shift linkage, axles, rear motor mount, and tranny mount will work.
as for emissions NO u will not pass emission cuzz the motor is older then the car unless u noe ways to bypass that then go for it.
Unceasing Measure
Re: (1baddc5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1baddc5 »</TD></TR><TR><TD CLASS="quote">well excuse me genius i spelled it wrong wasnt thinkin best thing to do it just buy you mounts from hasport or ive heard that you can get them form jegs cheaper than anywhere or ebay but i dunno if i would trust ebay or not</TD></TR></TABLE>
You didn't spell anything wrong, you used the wrong word because apparently you've never read a book
Re: (Archidictus)
be sure you have the full uncut harness as well, integra mounts will fit as far as the upper tranny mount and rear mount, tho i do believe some EK's have the vertical driver's side mount, this will require u do but the conversion mount for about $150 or the L bracket for B-series, shift linkage (from an integra) axles including the half shaft. the rest should be plug and play!
ebp_dc2
02-23-2006 11:05 AM
