HELP - Wierd B16A2 VTEC Problem
So I had a Civic Pulled the motor (B16A2) And dropped it in my Del Sol (OBD1). I just got a wiring Harness for OBD1 to OBD2A for the P2P ECU i was using before and Wired it up and when Vtec pops its like as if I red lined and loses gear. I'ma Be doing some research now but ANYONE KNOW WHATS GOING WRONG?!
THANKS IN ADVANCE I REALLY NEED THE HELP!
I never narc'd on nobody!
Re: HELP - Wierd B16A2 VTEC Problem
So first off, what you're saying makes no sense. You're using an OBD1 harness, but an OBD2 ECU? It doesn't work that way. Get rid of the adapter harness, and get rid of the P2P. Get a P30, and your problem should be solved.
The Cars OBD1 so im using an OBD1toOBD2 Conversion Harness to hook up the P2P but its getting so annoying I might just do that.
vtecftw
08-11-2007 11:15 AM
pearl
06-11-2005 04:10 AM
