Straight Cut gear noise in first gear.
Old 10-13-2014, 12:22 PM
crazyhouse2011's Avatar
Default Straight Cut gear noise in first gear.
95 Civic EX 5MT, 150k miles
Okay. So today I noticed that around half the time I took off in first gear, my car made a VERY loud straight cut gear whine from the front end (im assuming the transmission). Only in first gear, and not on every single time I took off. It was on and off. As soon as i shift to second gear, the noise disappears. It sounds EXACTLY like reverse gear, just the noise is magnified.
It just started this today. I also feel it necessary to mention a few details:
-- My ISB has been noisy ever since I bought the car, January of last year.
--After driving for awhile today with this first gear issue, at ONE time It made a more faint straight cut gear whine in second gear, but it never happened again.
--One time I was doing fast shifts, 1 to 2, then on my shift from 2 to 3 (very fast in and out of the clutch, where the car kinda lurches a little bit) I heard the noise even fainter in third gear. I could not replicate this again.
What is going on here? I've heard 1st gear bearing might be bad, I also read my clutch could be giving me issues?
I replaced my tranny fluid with Honda OEM a month and a half ago, with no noticeable effects.
Last edited by crazyhouse2011; 10-13-2014 at 01:03 PM. Reason: People's jimmies getting rustled over technicalities
crazyhouse2011 is offline
Old 10-13-2014, 12:46 PM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: Straight Cut gear noise in first gear.
You're beating on a worn out transmission, shifting wrong, and you're wondering why you're having problems? Are you trying to blow it up? If you are, you're doing a damn good job of it.
NotARaCist is offline
Old 10-13-2014, 01:02 PM
Im thinking your referring to the part where I used the word launch. When I say launch I mean take off normally..... so from now on i will say "take off". No, i didn't do any hard driving, just in a hurry around the city.
EDIT: Edited OP to fix the etymological issue here.
Old 10-13-2014, 01:23 PM
NotARaCist's Avatar
And your "fast shift" stupidity. If the car is lurching, you're shifting wrong. You're beating on a transmission that you admit is failing, with the ISB going out. You've probably sent the ISB from failing, to "what the **** are you doing to me", which would perfectly explain the problems you're having. "Fast shifting" is not healthy for a standard, synchronized transmission. I don't care what you've seen them do in movies - it doesn't work like that.
Old 10-13-2014, 02:05 PM
I did it once. The car didn't really lurch, it's just the revs dropped faster to match the wheel/tranny speed (at the expense of the clutch). You can feel and hear this but by no means is it drastic.
Once again, I did it ONE time. So that's not the issue here.
Still waiting for help here. My internet searches aren't really getting me moving in the right direction.
Old 10-13-2014, 02:46 PM
NotARaCist's Avatar
I guess I'll say it again, in more plain words for you this time.
Your
Input
Shaft
Bearing
Is
Fucked
Old 10-13-2014, 02:56 PM
Thor294's Avatar
sounds like ISB is on its way out
Thor294 is offline
Old 10-13-2014, 03:01 PM
Fish Twig
tony_2018's Avatar
You guys who open threads need to really know what your saying. Even I read it as you were really getting on it.
tony_2018 is offline
Old 10-13-2014, 04:04 PM
UPDATE!!!!!
I noticed as i was driving around just now, the car shuddered when taking off. It felt almost floaty. Rough launches. The shift **** vibrated a **** ton decelerating in 4th gear. There were god awful loud screeches, sounding like wet things squeaking together, and loud knocking and rattling noises. At one point i swear i smelled transmission fluid. I noticed starting in second gear made this whole scenario more livable, but as i limped her home I was on the edge of my seat. I parked her for now. Its rainy and dark outside so please dont ask me to check for fluid leaks or the like.
What happened?
Old 10-13-2014, 04:11 PM
Thor294's Avatar
Transmission go bye bye. Pull it out and fix it
Thor294 is offline
Old 10-13-2014, 04:25 PM
My first instinct was to sell the bitch. But I thought maybe if I replace the ISB, it will run again? Can anybody confirm this? It makes really nasty noises but stops when i push the clutch in, so im assuming the ISB broke or something.
Old 10-13-2014, 04:42 PM
NotARaCist's Avatar
Your
Input
Shaft
Bearing
Is
Fucked
I can't make it any more plain than this for you.
Old 10-13-2014, 05:02 PM
joey1320's Avatar
OP so for over a year and half you have had what you think is an ISB noise and now you are surprised that your trans is fucked? Muahahahahahahahaaahhhha.
Why would you not fix the problem imediately? Why even bother changing the trans fluid knowing quite well you have an internal problem?
Take this trans out, scrap it and find another one...
joey1320 is offline
Old 10-13-2014, 05:06 PM
i get that. dont be a dick head
Old 10-13-2014, 05:07 PM
one member on here said they had a bad ISB and drove on it for years with no issues. i made a thread about this in february 2013. i can dig it up if you all need proof.
Old 10-13-2014, 05:12 PM
joey1320's Avatar
I heard of a man who survived a 1" drill bit going thorugh its head... You wanna try that too?
Just because some dickwad here told you his car did fine, doesn't mean your will do the same. Sorry bro, you should had done what was needed then...
joey1320 is offline
Old 10-13-2014, 05:49 PM
Thor294's Avatar
Thor294 is offline
Old 10-13-2014, 05:51 PM
Fish Twig
tony_2018's Avatar
Nobodies gonna be able to tell you that because...........basicly we don't know whats going inside YOUR transmission. If you have the ***** to take it apart and JUST replace the bearing than go for it, what do you have to lose but time. At least you can say you were able to take apart a transmission.
Old 10-13-2014, 06:23 PM
NotARaCist's Avatar
I drove with a failing ISB for a little over a year, but I also didn't drive it harder than your average grandmother until I fixed it. You, on the other hand, are ragging on your car and wondering why it's shitting on you. At this point, you may have very well shot out your ISB, and caused enough endplay to damage your gearsets, or even your differential.
Take the transmission off. Rip into it, measure everything for spec, and replace ALL of your bearings, seals, and synchros. While you're doing that, start hoping that you didn't chew down your gears, bend your shift forks, or wallor out any mounting points for your shafts.
Old 10-13-2014, 07:00 PM
well im considering trading this heap for a dsm
Old 10-13-2014, 07:01 PM
i coulda sworn it was you that told me that you drove on a bad isb for awhile.......
i wish i woulda known the second part, about taking it easy. I did about 5 or 6 hard launches, IE smoking the tires, in the past few months. I also drag race from time to time. Musta blown up the ISB pullin dat sheet
Old 10-13-2014, 07:39 PM
Former User's Avatar
the car shuddered when taking off...The shift **** vibrated a **** ton decelerating in 4th gear. There were god awful loud screeches, sounding like wet things squeaking together, and loud knocking and rattling noises. At one point i swear i smelled transmission fluid.
Clutch chatter? Possible oil contaminated clutch?
Former User is offline
Old 10-13-2014, 07:52 PM
Fish Twig
tony_2018's Avatar
I would never understand why people do this kind of thing even they know they have a problem with the transmission.
Old 10-13-2014, 08:09 PM
NotARaCist's Avatar
Trading a car that would be perfectly reliable if you hadn't abused it, for a car that's known for being unreliable. Yep, great idea you've got there
Old 10-14-2014, 07:23 AM
dsms are reliable
Quick Reply: Straight Cut gear noise in first gear.
