bigger front disk brakes???
if i install a bigger front disk brakes on my car do i need bigger calipers or would the stock one work??? and the disk brakes size are 14 might be a dum question but just wondering
Re: bigger front disk brakes??? (nek9)
If you plan on auto crossing your car or tracking it, then when you put a big brake kit in, normally, they come with bigger calipers.
Thats pretty much your only option when it comes to brakes. Youll need a bigger set of rims too if you havent already gotten 16's or 17's.
Look around though, Im sure there are options out there. What kind of car?
Re: bigger front disk brakes??? (Red_EM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_EM2 »</TD></TR><TR><TD CLASS="quote">If you plan on auto crossing your car or tracking it, then when you put a big brake kit in, normally, they come with bigger calipers.
Look around though, Im sure there are options out there. What kind of car?</TD></TR></TABLE>
what are you talking about? he has tons of options. like switching to 99-00 si, 94-01 integra or JDM EG6/EK4 brakes. or, to be even bigger, ITR or CTR brakes. bigger? ITR or CTR brakes with NSX/legend calipers/rotors way better option then a BBK and fraction of the cost at times. the most important part of a brake set-up, the upgrade that will make the MOST diffrence is the brake pads...get metal masters FTW. and just brembo blanks will work. dont bother with drilled/slotted rotors, they are worse then blanks.
Re: bigger front disk brakes??? (Sleepy_Red_hatch)
yes im planing on autoX my car and its a 98 civic hb and tha tdosnt realy ans. my question...
with bigger discs you will need either bigger calipers or a new caliper bracket. but its dumb to use the same caliper because you will have the same contact surface as before.
