Rotor/spindle issue
Rotor/spindle issue
So I'm having the problem and I am unsure of what exactly needs to be replaced. I have the rotor secured to the spindle on the front knuckle and I can wobble the rotor and hub by pressing on one end of the rotor and back on the opposite end of the rotor. Perhaps its the bearing... any suggestions on what is wrong and what needs to be replaced?
Re: Rotor/spindle issue (SleepEMike)
Just the rotor wobbles or the whole hub? Put the little screws in the rotor, then put the wheel on and try it. Does it wobble up and down or side to side?
Re: Rotor/spindle issue (Archidictus)
^^ not neccessarily a bad wheel bearing... you know you have a bad wheel bearing when i makes noises driving if it is wobbling left and right then u need a new rack-n-pinion arm
Re: Rotor/spindle issue (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch »</TD></TR><TR><TD CLASS="quote">Just the rotor wobbles or the whole hub? Put the little screws in the rotor, then put the wheel on and try it. Does it wobble up and down or side to side?</TD></TR></TABLE>
The whole hub wobbles... side to side, up and down, every-which-way like a quarter inch when looking at the rotor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chingpo05 »</TD></TR><TR><TD CLASS="quote">^^ not neccessarily a bad wheel bearing... you know you have a bad wheel bearing when i makes noises driving if it is wobbling left and right then u need a new rack-n-pinion arm </TD></TR></TABLE>
the rack-and-pinion is fine, just the hub and secured rotor wobbles... guessing its the bearing and or knuckle
CXHatchback
10-16-2003 04:16 PM
