oil breather chamber cleanout
I want to clean out the oil breather chamber on the back of the engine block. I believe it's plugged after 14.5 yrs and 270,000miles. I was going to use degreaser. Any thoughts?
Unceasing Measure
Re: oil breather chamber cleanout (dpkelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpkelly »</TD></TR><TR><TD CLASS="quote">I want to clean out the oil breather chamber on the back of the engine block. I believe it's plugged after 14.5 yrs and 270,000miles. I was going to use degreaser. Any thoughts?</TD></TR></TABLE>
That will work fine, although it would probably be more beneficial to just replace it.
Re: oil breather chamber cleanout (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
That will work fine, although it would probably be more beneficial to just replace it.</TD></TR></TABLE>
Except it's under the intake manifold and impossible to get to unless you take it off. Damn, I should have replaced it when I was replacing the headgasket.
Cheers.
Cheers.
top
03-19-2007 01:31 AM
