trans prob
trans prob
ok im new to hondas. what can I say im a supra and rx7 owner. but yes i acculy blew a d16y8 motor in 4 days with no mods and no redlineing and good oil in it too. but my cheap *** boss got me a d16y7 motor and i put it in today but now the trans is very hard to shift into 1st and rev. but when moving its ok bec i rev match and speed mach all the geers and well its not the smothist but its ok. btw I didnt remove the old motor from the car and they put in a new clutch and just left it as a long block on the ground and i had to put it in. any one got any ideas about this. also i put 10/30 oil in the trans??? is this right??? some one was saying that the clutch disk could be backwards
Re: trans prob (98ekturbo)
If the trans worked fine before, and using the same trans, ya I'd say an install/clutch issue, it kinda sounds like that anyway. Check your shift linkage and make sure not bent or anything goofy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juevi »</TD></TR><TR><TD CLASS="quote">If the trans worked fine before, and using the same trans, ya I'd say an install/clutch issue, it kinda sounds like that anyway. Check your shift linkage and make sure not bent or anything goofy.</TD></TR></TABLE>
I would say check the shift linkage and make sure it's not overtightened..
Though you said..it's hard to rev? It's more than just the clutch if that's your problem.
PS: What setups were u running on ur supra and rx-7? Years?
thank you for the help ill pull the trans today at work. lucky me.lol but yea Im still building my supra and the rx7 is in minnasota right now the supra will be a road race king no crazy power just good tuning and handling and the rx7 is gonna just be my daly driver with just pipes and intake. mostly looks. not realy bec its just gonna be white and have wheels. I work at a speed shop so I like my cars to be fast but clean and kinda stock looking. lol
