wiring??????
Re: wiring?????? (S2k Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2k Hybrid »</TD></TR><TR><TD CLASS="quote">What gato meant to say was
-if does not have directions, try a search and you should come up with an answer.
yep
yep
HT White Ops
You two are ******* worthless. At least help the guy.
Here's a how-to with some pictures. It's really easy. You wire power to a 12v ignition-dependent source, ground to chassis, and signal to the O2 sensor wire on your ECU wire or directly to the O2 sensor.
How-To With Pics:
http://www.team-integra.net/se...D=668
OBD1 ECU Wires:
http://technet.ff-squad.com/wiring.obd1.htm
OBD2A ECU Wires:
http://technet.ff-squad.com/wiring.obd2a.htm
OBD2B ECU Wires:
http://technet.ff-squad.com/wiring.obd2b.htm
How-To With Pics:
OBD1 ECU Wires:
OBD2A ECU Wires:
OBD2B ECU Wires:
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">You two are ******* worthless. At least help the guy.
also you can try
http://www.egauges.com/pdf/AutoMeter/837j.pdf
also you can try
camp_kill_yourself
01-05-2007 11:44 AM
J Rob
12-18-2005 03:24 PM
