inner tie rod?
inner tie rod?
ok i went to get an alignment the other day and they said they could not align it because i have bad tie rods therefore voiding the warrenty.. i have searched for hours found some helpful threads but none that will help me fully accomplish the job can anyone give me some step by step methods to change the inner tie rod? without taking off the steering rack completely? pictures anything would be helpful..i also know there is a special tool can someone give me a link or pic of what it looks like? thanks
Re: inner tie rod? (305accord)
http://www.mytoolstore.com/astro/asthan14.html
thats what it looks like. it is fairly easy take off the outer tie rod. remove the boot by taking the clamp off the inside. take a look at where the tie rod is connected on the rack and make sure there is no pin holding it. place the right adapter on the tool, slide it over the inner tie rod and turn it off. might be a little tuff so make sure you have a breaker bar. might want to put some lock-tite on when installing it. thats what i do at work but it is up to you. good luck
