Idle Problem in my EK
I have a b20b with an odb1 conversion running on a 92 LS ECU. At first, the idle would bounce from 800 to the point where it would almost die out. Then the check engine light came on. After about a week or so my idle stopped bouncing but it now idles at 2-3.5k depending if my car is warmed up. When i engage the clutch to when the car starts to move the idle is normal for that 2 seconds that it catches gear. But once i put it in neutral the idle is back at 2k. I just checked the check engine light and its 41 Primary oxygen sensor heater. I dont know what that has to do with my idle problem. Any feedback would be good. Thanks.
Nisif
11-26-2011 07:22 PM
