Need to rethread the thick bolt for front seat - anyone knows what size to use??
I happend to strip the thread, so i need to fix it but anyone knows what size to use?? this is the thickest one of 4, the other 3 are thinner..
thanks
thanks
Re: Need to rethread the thick bolt for front seat - anyone knows what size to use?? (Ser1N)
pull it out of the passenger side and go get two new ones from you local hardware shop. That would be your best bet
Re: Need to rethread the thick bolt for front seat - anyone knows what size to use?? (TDSI99)
the actual thread inside the hole is stripped.. most of honda bolts are grade 10 and most hardware stores don't sell grade 10 bolts.. i guess i'll just take the bolt there to measure it.. i have extra bolt btw..
Re: Need to rethread the thick bolt for front seat - anyone knows what size to use?? (vtec.dc2)
forgot about helms.. it shoudl be 10 x 1.25 and the other are 8 x 1.25
if its one of those holes that go through the floor (when removed you see the ground underneath the car) then just use a bolt that fits through the whole and use a nut on the other side
Re: Need to rethread the thick bolt for front seat - anyone knows what size to use?? (DeadEnd9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">if its one of those holes that go through the floor (when removed you see the ground underneath the car) then just use a bolt that fits through the whole and use a nut on the other side</TD></TR></TABLE>
hMm wonderful idea i think ill be doing that!
ZC88CRX
15
05-13-2011 12:58 PM
