SKunk2 Camber kit 95 EG, Steering has mind of it's own....
I installed skunk2 front and rear camber kits, then had it professionally aligned. About 6 months later, the tread on both front tires has dwindled down to nothing, and when I take a corner, the steering wants to force itself in that direction. Also, the steering wheel seems to shift about 10 degrees off in various directions when driving strait.
Any ideas as to what I should adjust/have someone look at?
Re: SKunk2 Camber kit 95 EG, Steering has mind of it's own.... (EGJason)
Yikes! Have you checked to see if the bolts that hold the ball joint in place have loosened?
Re: SKunk2 Camber kit 95 EG, Steering has mind of it's own.... (jg)
did you rotate the tires? the tires play a big part if they are directional tires not installed properly.
check everything
did they tighten everything????
check everything
Re: SKunk2 Camber kit 95 EG, Steering has mind of it's own.... (EK9Rider)
Yes, I just rotated the tires yesterday. The ball joint seems snug as a bug in a....
baca00ex
20
10-19-2010 06:43 PM
kcem1
Suspension & Brakes
08-04-2005 02:43 PM
