brake booster hose
brake booster hose
removed hose to reroute.. apon putting the hose back im unable to really build pressue.. when i first started the car the hose was loose.. dont know if that matters...
Re: brake booster hose (oc_civic)
MAKE SURE THAT CHECK VAVLE IS THE RIGHT WAY AND YES IT DOES MATTER IF THERE IS NO CLAMP ON IT, PUT THAT **** ON, IT'S A VAC. LINE
Re: (1992Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si »</TD></TR><TR><TD CLASS="quote">Did you put the check valve in backwards?
great call.. when you said that i said to myself i dont remember seeing a valve... and i didnt because the valve is hidden within the hose as per page 19-23 in the service manual.. good call
Modified by oc_civic at 6:43 AM 11/5/2007
djnikko
11-05-2004 08:02 AM
