radiator woes and check engine light. need input/comments
One of my cars recently had a radiator incident and then I replaced the radiator with a used one I bought off HT. This is a civic with swapped b16a2. It's now throwing a check engine light, but i'll be able to rent a code reader tomorrow.
Anyways, I just wanted some input before I'm able to get the CEL code.
Here's a quick rundown:
I just replaced the radiator with a used one I bought. I was told the radiator was still good, but I can't be positive on that one yet.
Car had a major coolant leak at the heater core and all coolant leaked out while I was driving the car, temp gauge got pretty high, but only for a minute (I was very near my house and was able to drive home quickly).
I cleaned up the mess and replaced the heater core.
I filled up all the coolant levels and burped the system of air, ran the car until the fan came on twice, shut the car off, and checked/filled up any fluids.
Now, I run the car and it throws a CEL. The car idles rough from 1k-1500k rpm. The temp gauge stays in the normal area, and both radiator hoses get warm, so it would appear the cooling system is working at least.
Did I blow the head gasket when the car overheated that one time? Also, would a bad/leaking radiator throw a CEL and cause rough idle? Would a blown headgasket throw a CEL? Any other ideas?
any help is greatly appreciated~
Re: radiator woes and check engine light. need input/comments (ej_type_R)
u need to get the code for CEL and radiator wont throw any CEL
click the link https://honda-tech.com/zerothread/1901557
Jack Murphy
11
06-12-2017 09:01 AM
Mercuryrising17
01-21-2013 06:06 PM
Project_ED8
24
11-22-2003 12:16 AM
4doorH22
18
01-19-2002 01:06 PM
