help, my radiator fan is not working.
hello, my radiator is not spinning when a turn on the car, is it because the engine is not hot enough thats why is not working? or it should spin regardless the temperature? also the fan on the left side is not working, is it the A/C fan? pls help me out, thanks.
Re: (pearlcfcivic97)
oh thanks man, so if i turn on the A/C the left side fan will spin right? also, how do i know if my radiator fan is working properly? should I run the car for like 30 mins? then check if the fan is spinning? what can i do? thanks.
just take the wires from the fan, ground 1 straight to the frame and wire the power to the ignition, it'll be on all the time, but if it gets cold around your area, wire it to a switch , so you can have it off until you're warm, i did that, works great.
AgentJam
07-01-2005 05:23 AM
