injector resistors
injector resistors
I have an H22A and that I am swapping into my eg. The swap came from a eg befor mine so I am getting alot of things alredy done for me, but I am trying to solve this puzzle. Do all the h22 injectors and ecu's have resisteors becues I did not get one off the other eg. I am running a usdm p13.
So my finnal question is, will the usdm p13 with the usdm injectors need a resistor box and if they are jdm injectors with the usdm p13 I would need to run a resistor box? how can I tell if the injectors are jdm or usdm.
For the jdm vs. usdm injector issue, i dont think that makes a difference of compatability, and i doubt (but dont know) theres a way to tell, because there just injectors. I dont know if the h-series have resistor box so try a search on h-series injcetor impedance (resistance or ohms), if its low like 3~5 it requires a resistor box, if its like 11~14 it saturated and doesnt need one. As long as you have the ecu for that motor you should be good on that part.
Re: injector resistors (Colby71)
off mitchal
it said
Injector 1.5-2.5
Injector Restior 5-7 Both in Ohms
My question is Now do I need to get a honda resistor box or is there something eles I can use becues i live in the sticks and it will take a fue days befor I get them. so like resisters from napa or something?
Modified by Colby71 at 8:13 PM 12/13/2007
it said
Injector 1.5-2.5
I dont know if i would try making one, because of what could happen because of weather and keeping it sealed. Im think any resistor box off of a honda will work, some older crx's i think had them, and integras, ebay it possibly, there every where on there.
right now it is running without the resisters and it had been for a long time befor I got the motor so if i burn up an ecu I will put them in or if I get a hondata or a tunning something I have put more money into. who knows might jst put one in sometime.
Sassafrass
10-09-2004 09:58 PM
