driveshafts???
driveshafts???
hello there i have a B16A2 (95) engine and the car it is going into is a Honda Civic Coupe 2000 (W reg) i have got the engine into the car and mounted what i need 2 know is if i get the driveshaft that fits into the b16 will the fit into the stock hubs on the wheels or will i need 2 convert them to a 95 hub. so all what i need 2 know will the b16 driveshaft fit into my coupe stock hubs?? and can i have reconmendasion on what is the best driveshaft 2 get?? thank you in advance and sorry for spelling errors
Resident Gearhead
Re: (Power_of_Dreamsx)
First, I'm sure you're talking about a EDM engine which I'm not too familiar with, but was it called a B16A2 in 95 over there?
Anyway to answer your question, the axles from the 95 will work for the 00, as long as the 95 intermediate shaft (half shaft) is used.
Drive Shaft Shop is great and I, as always, recommend Raxles too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power_of_Dreamsx »</TD></TR><TR><TD CLASS="quote">who are frank and lee? </TD></TR></TABLE>
They work for the Drive Shaft Shop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si »</TD></TR><TR><TD CLASS="quote">Most will tell you to call the Drive Shaft Shop. Frank or Lee will take care of you.
first off, going with axles from drive shaft are a bit unnecessary, unless the OP plans on puting down some huge numbers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power_of_Dreamsx »</TD></TR><TR><TD CLASS="quote">hello there i have a B16A2 (95) engine and the car it is going into is a Honda Civic Coupe 2000 (W reg) i have got the engine into the car and mounted what i need 2 know is if i get the driveshaft that fits into the b16 will the fit into the stock hubs on the wheels or will i need 2 convert them to a 95 hub. so all what i need 2 know will the b16 driveshaft fit into my coupe stock hubs?? and can i have reconmendasion on what is the best driveshaft 2 get?? thank you in advance and sorry for spelling errors </TD></TR></TABLE>
the axle shaft on the b-series axles are the same as your 2000 civic, so mounting the axles are a breeze, not custom work.
as for axles, you can go with any axle from a parts store. as long as they are for a b-series motor. going with axles from drive shaft are not bad, but expensive. if this is something like a daily driver w/ a couple of bolt ons, then regular axles are fine.
Resident Gearhead
Re: (KidSenation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">the axle shaft on the b-series axles are the same as your 2000 civic, so mounting the axles are a breeze, not custom work.
as for axles, you can go with any axle from a parts store. as long as they are for a b-series motor.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KidSenation »</TD></TR><TR><TD CLASS="quote">Like he said^^^ any B series axles will work.</TD></TR></TABLE>
If you get axles for a B-series 92-95 Civic, you will need a 92-95 B-series intermediate shaft. If you get axles for a B-series 96-00 Civic, you will need a 96-00 B-series intermediate shaft.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcvtec »</TD></TR><TR><TD CLASS="quote">Anyway to answer your question, the axles from the 95 will work for the 00, as long as the 95 intermediate shaft (half shaft) is used.</TD></TR></TABLE>
Re: (mcvtec)
i've never done that, actually i have a 98 civic w/B16A (95) and i never swapped out the intermediate shaft.
Resident Gearhead
Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">i've never done that, actually i have a 98 civic w/B16A (95) and i never swapped out the intermediate shaft. </TD></TR></TABLE>
I was wrong, and you are right. I was thinking that the 92-95 int shaft was female on the axle side. My bad
Re: (mcvtec)
I was wrong, and you are right. I was thinking that the 92-95 int shaft was female on the axle side. My bad </TD></TR></TABLE>
01 black gsr
09-27-2008 10:46 AM
superls92
08-03-2003 05:56 PM
