e-brake light
e-brake light
Well, i've got an interesting issue with my e-brake. The light on the cluster stays on even after i've released the e-brake. It doesn't do it all the time, only when its a cold start (in the early morning / late evening). When it does this, it stays on until I turn the car off and have a "warm" startup. I'm not sure if that's linked to it, but there's at least SOME connection. I have sufficient brake fluid and i've tried new master cylinder caps. I was thinking it MAY be the e-brake switch, but I think it'd cause it to stay on all the time. Thoughts / ideas?
Re: e-brake light (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">i'd say take off the e-brake console and check if the switch is contacting metal</TD></TR></TABLE>
ill try that, thanks. Any reason it only do it when cold though?
Re: e-brake light (sk8shorty012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8shorty012 »</TD></TR><TR><TD CLASS="quote">
ill try that, thanks. Any reason it only do it when cold though?</TD></TR></TABLE>
May just be cause its not making sufficient contact. The cold may just be a coincidence, Although, cold weather has been known to do a number of odd things to cars. Checking the wire contact would be the place to start.
Re: e-brake light (97Ej6mike)
searching for this cuz i'm having the same prob. for the most part, odd thing is tho, when i apply the brake, the light goes off temporarily. i had a 98 prelude that did this in the cold winter's every now and again. any other ideas?
Re: e-brake light (BIG_BOSS)
This happened to me. Only on cold starts it would come on but when warm the light would stay off. After like a two weeks it just stopped coming up when i didnt even do anything.
Re: e-brake light
Bump for an old thread...
I am having the same issue. brake light comes on during a cold start, and then will go off when it warms up, unless it is really cold out, then it will only go off when I hit the brakes and it may or may not come back on. I was thinking maybe it was a vacuum issue but I am not sure.
Any insight?
EDIT
I think this may fix the issue, looking like a bad/clogged filter.
http://www.tegger.com/hondafaq/tsb/crv/x03-078e.pdf
Any insight?
EDIT
