Cluster Problem
Cluster Problem
I have a 94 Civic Si and the stock gauge cluster is acting up on me when i am driving.When the car is moving the needle on MPH will constantly jump up and down from about 40 to 120 mph.Once i come to a stop it also stops and then once i am driving it happens again. Anyone know whats the prblem or can give me an idea where to start with this??
Re: Cluster Problem (archuletac)
does it do it constantly or every now and again? I used to hit my cluster hard and it would work for 5 secs then go back to acting up again.
I have this problem too but my odometer seems right on. I think my speedo is bad ill have to swap it, I have another but the mileage is twice as much.
Re: (pearlcfcivic97)
i pulled my vss out and checked it.seemed fine and i clipped it back in.My speedo worked normal for awhile until i got on it.when i give it full throttle it went crazy again and now i am throwing a cel 17 for vss.Is a new vss needed for sure??
HRD PKR
Re: Cluster Problem (wangkata)
Replace the VSS. vehicle speed sensor. Before you re-install the new one make sure their is no corrosion in the connector on the harness
