Ls swap
Ls swap
Whats goin on honda-tech i need your help. I own a 96 civic hatchback cx i jus finished droppin a obd2 ls swap... 1. I reused the stock harness on the ls there some plugs dat dnt plug into nothing cuz there no more plugs to plug them onto what should i do?? 2 when i was trying to connect the throttle cable.... I wasnt able to connect beacause it was short so what cable do i need for it to work??? 3. Can someone tell how to put in a dizzy on the ls motor or give me a link to a write up on how to....................thanks
Modified by ek9hatch87 at 10:21 PM 3/31/2008
-if you have extra plugs usually its ok cause the ecu wont ask for those readings anyway, when i did a LS swap in my 00 civic i had extra plugs too cause i used my stock harness
-is the trottle cable too short or will it reach and you cant mount the stock mounting thing anywhere? i had to loosen the mount on the cable and hammer it flat and do some stuff to it to make it work with the LS manifold but i got it to work
g_man80
01-31-2003 08:29 PM
