Whats the diff btw HiFlow Cat and Test pipe
Old 04-01-2008, 06:36 PM
thaiboiz's Avatar
Default Whats the diff btw HiFlow Cat and Test pipe
Whats the diff btw HiFlow Cat and Test pipe??
i have 99CivicEx, and my oem cat was broken internal, i didn't have budget to buy the oem cat right now...so i went to the local race shop...and ask the guy to install the cat converter...he show it to me ...and he install it for me...my car ran great but it is so loud
and i wonder if the guy put the hiflow cat or test pipe in my car...how can i tell the diff??? and whats the diff btw those? thanks
Old 04-01-2008, 06:39 PM
z6hatchboy's Avatar
Default Re: Whats the diff btw HiFlow Cat and Test pipe (thaiboiz)
A high flow cat will still have some kind of woven material in it and serve the purpose of a cat, a test pipe is just a straight piece of pipe with flanges on both sides, or a "cat-delete".
Old 04-01-2008, 06:43 PM
95sloweg's Avatar
Default Re: Whats the diff btw HiFlow Cat and Test pipe (z6hatchboy)
hi flow cat- theres a chance to pass emissions, but i heard stories where some couldnt with it on.
test pipe- you have no chance at passing emissions.
Old 04-01-2008, 07:14 PM
thaiboiz's Avatar
oh i see...thanks
i have hight flow cat installed on my car...but it doesn't sound very good...i got obx exhaust....do u think by install header my car will sound better?
Old 04-01-2008, 07:15 PM
thaiboiz's Avatar
Default Re: Whats the diff btw HiFlow Cat and Test pipe (95sloweg)
i lived in FL..and there is no emissions here...so im good
Old 04-02-2008, 10:18 AM
thaiboiz's Avatar
and right now i got check engine light
it showing the code P0420 Catalyst effiency below thrshole (bank1)...anyone know whats causing this? and does it gonna effect anything?
Modified by thaiboiz at 2:40 PM 4/2/2008
Old 04-02-2008, 10:37 AM
1990 crx dx b's Avatar
Get a cat and save us from emissions, it only robs you of like 2hp. I don't want deadly gasses flowing around.
Old 04-02-2008, 10:44 AM
97Ej6mike's Avatar
A highflow cat, by some luck, may get your thru inspection. A test pipe will land you a $500 ticket (depending on state laws)
Old 04-02-2008, 10:51 AM
ho bag's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiboiz &raquo;</TD></TR><TR><TD CLASS="quote">Whats the diff btw HiFlow Cat and Test pipe??
and i wonder if the guy put the hiflow cat or test pipe in my car...how can i tell the diff??? and whats the diff btw those? thanks</TD></TR></TABLE>
Well if you comparing an ebay high flow cat to a test pipe then there is no difference. If you get a real high flow cat then yes it still does its job just not as well.
Old 04-02-2008, 11:13 AM
m0nee's Avatar
You can usually tell a test pipe from a hi-flow. Most cheap test pipes are just a regular exhaust pipe with two flanges on the end. Hi-flow has a hump in between the two flanges with flat top and bottom. Most of those chrome ones on Ebay claims to be high-flow, but they're just test pipes (no mesh inside). Carsound Magnaflow sells the real high-flow cats.
Hi-flows (carsound)
http://cgi.ebay.com/ebaymotors...ZWDVW
Test pipes (the description says straight thru) = Test Pipes
The most obvious Test-pipes
You said your cat was [freak]ed, so just bust out all the inside material with a metal rod, and waa-laaah, you got yourself a test-pipe! then take those materials to a scrap yard and receive $80-$100 for the platinum.
Old 04-02-2008, 11:36 AM
D50boy's Avatar
Default Re: Whats the diff btw HiFlow Cat and Test pipe (m0nee)
This is a test pipe. Loud and does nothing for emmissions:
A high flow cat is jsut like the stock cat but has wider inlets and outlets. It also has this stuff inside which reduces emmissions:
It shouldn't be out of the cat but if you own a piece of crap Carsound, it'll blow out of the tailpipe on its own
And ebay will have their "racing cat" which is just a resonated test pipe. They have punched pipe inside that works like a fart can style muffler and does nothing for emmissions.
Old 04-03-2008, 05:55 PM
thaiboiz's Avatar
thanks everyone..!!!
now i know the diff
i just got resonated test pipe
DCSportEJ1Civic
26
07-16-2007 12:44 PM
Fat Chick Magnet
08-04-2006 04:33 PM
Scud
07-26-2006 07:54 AM
00PurpleGSR
04-13-2002 03:29 PM
vtec power
07-30-2001 09:32 AM
Quick Reply: Whats the diff btw HiFlow Cat and Test pipe
