VTEC pressure valve ecu code
I just put together my ls/vtec set up. i put a new valve train in with stock cams and everytime i hit vtec in 3rd gear i get a "VTEC pressure valve" code. the code came up on my first vtec solenoid and i changed the solenoid and now the code is still popping up with the new vtec solenoid. i was wondering if this happen to anybody and what did they do to solve the problem.
Re: VTEC pressure valve ecu code (keychild486)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keychild486 »</TD></TR><TR><TD CLASS="quote">the original solenoid was us and i replaced it with jdm and still getting the same result</TD></TR></TABLE>
A jdm solenoid does not have a vtec pressure switch.
Bypass the vtec pressure switch per the instructions on http://www.phearable.net/tech
Re: VTEC pressure valve ecu code (mtber)
which link do i click on for directions. also which switch is the oil pressure switch on the solenoid the green or the gray switch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keychild486 »</TD></TR><TR><TD CLASS="quote">which link do i click on for directions. also which switch is the oil pressure switch on the solenoid the green or the gray switch?</TD></TR></TABLE>
Click on "How to bypass vtec oil pressure switch"
thank you very much for your info one more question i know the jdm solenoid doesn't have a oil pressure switch so you mean when the code came up for the usdm solenoid does that mean my usdm solenoids oil pressure switch wasn't working?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keychild486 »</TD></TR><TR><TD CLASS="quote">thank you very much for your info one more question i know the jdm solenoid doesn't have a oil pressure switch so you mean when the code came up for the usdm solenoid does that mean my usdm solenoids oil pressure switch wasn't working?</TD></TR></TABLE>
Possibly.
Possibly.
PnkRokCountryboy
09-02-2007 02:21 PM
VTC_CiViC
11-17-2004 09:05 PM
