CEL with VTEC
Old Apr 1, 2008 | 02:36 PM
Jman8108's Avatar
Default CEL with VTEC
Im having a problem. I have a z6 in my hatch and i recently swapped out the tranny for another ex-si one. Since the swap I have been having a CEL problem. When I start the car and drive normally it is fine, no CEL, but whever I hit VTEC a CEL comes on. Usually it is after I shift when it comes on. Then if I turn off the car and start it again, voila, no CEL. Anyone know how to fix this or atleast what the problem is? Thanks for the help
Old Apr 1, 2008 | 02:53 PM
95jeremie's Avatar
Default Re: CEL with VTEC (Jman8108)
is your spedo consistent? bouncing? rpm's?
check oil level and pressure
Old Apr 1, 2008 | 03:01 PM
Jman8108's Avatar
Speedo is consistant.
I just checked my oil level and it is past the 2nd dot on the dipstick.... could having too much oil cause that? Should I drain some out?
Old Apr 1, 2008 | 03:05 PM
95jeremie's Avatar
Default Re: (Jman8108)
how far past?
that's not the problem...
try pulling the vtec solenoid and cleaning off the screen and reinstalling it
or better yet try a friends.
i had one go out on me in the past. just pulled one off my old motor and it's good to go.
Old Apr 1, 2008 | 04:06 PM
z6hatchboy's Avatar
Have you tried pulling the the cel? I've seen this a bunch of times before, but cant qtuie remember what it is, im thinking a sensor.
Old Apr 3, 2008 | 06:42 PM
Jman8108's Avatar
Sorry but what do you mean by pulling the CEL?
Old Apr 3, 2008 | 06:54 PM
95sloweg's Avatar
"pulling the CEL" means finding out what the code is. here a how to if you dont know how to do it https://honda-tech.com/zerothread/1901557
Old Apr 4, 2008 | 10:25 PM
Jman8108's Avatar
Problem with that is I cant pull the code because when I shut the car off the CEL goes away....
aklano
Apr 1, 2011 11:53 AM
chaokongz
May 3, 2009 10:35 AM
what gsr
Apr 4, 2006 07:08 PM
vti-R
Aug 20, 2001 09:41 PM
