b16a2 swap into a 92 civic lx
Ok, screw the turbo d16 idea, I got a b16a2 from a 1999 civic, and a p75 ecu. I'm wondering what all I will need to do the swap. First off; wiring. I've seen obd1 to obd2 conversion harnesses. Is that all I will need to do to have all the wiring right? Do I need shift linkages or will my stock ones work? Does it matter what kind of b series transmission I use? A list would help a lot. Thanks, David
Re: b16a2 swap into a 92 civic lx (z6hatchboy)
mostly all the posts ive seen are swapping a b16a2 into a civic si that already had vtec, so they use an integra wiring harness, and a p28, but I cant do that. I have my b16a2 harness, and the p75 that came with the motor. I'm guessing I will just need that conversion harness. Help would be appreciated. Thanks
Re: b16a2 swap into a 92 civic lx (turbo_d)
is this the right jumper harness I will need? Because I need to convert my harness that connects to my ecu to obd2 . Are all the honda cab harnesses that connect to the ecu the same? Im confused..........
This one converts from obd2 to obd1. I need one the other way around! (I think)
http://cgi.ebay.com/ebaymotors...ZWDVW
First off you cant use the b16 harness. You use your LX engine harness and add the pins for vtec.
You will then need to change the timing belt side motor mount to a 94-01 integra mount.
You wont need a conversion harness. A P28 will plug right into your car.
You will need any B series shift linkage.
Any b series axles will work as long as you use the matching mid shaft.
ANY B series tranny will work.
Re: b16a2 swap into a 92 civic lx (Ej Girl)
So I can use my stock harness? I have the b16a2 wiring harness, so do I just put all the sensors from the b16a2 harness onto the lx harness? Will I have to add wires to the main wires, or just solder some sensors onto the tips? Hope that made sense. Thanks, David
Modified by turbo_d at 10:21 PM 4/1/2008
Modified by turbo_d at 10:26 PM 4/1/2008
Modified by turbo_d at 10:28 PM 4/1/2008
EKcivicEK
10-25-2009 09:00 AM
pinoyboy204
05-21-2006 07:03 PM
