Help - Speedometer Stuck on 15 mph
Old 04-01-2008, 04:04 PM
m0nee's Avatar
Default Help - Speedometer Stuck on 15 mph
96 Honda Civic EX coupe
Common Problem? You tell me!
When I start up my car, the speedometer jumps to about 15mph and stays there, even when idle and when running. When it wants to work, it will just break loose, and goes into normal; it'll then operate and read accordingly. My friend's 95 Honda accord has this same problem also, so I assume it is common. Maybe someone can tell me the problem and how to fix it.
Thanks!
Old 04-01-2008, 07:12 PM
m0nee's Avatar
Default Re: Help - Speedometer Stuck on 15 mph (m0nee)
help?
Old 04-01-2008, 08:43 PM
grandtheftlunchbox's Avatar
youll have to replace the cluster.
reason being because the VSS (vehicle speed sensor) generates more voltage at a greater frequency as you accelerate. it is impossible for the VSS to generate voltage at a complete stand-still. and if wiring was a problem, the needle would either stay dead at 0 or be completely maxed out. therefore it has to be your cluster. have fun!
Old 04-01-2008, 09:19 PM
m0nee's Avatar
Default Re: Help - Speedometer Stuck on 15 mph (grandtheftlunchbox)
wow, that makes sense. That was going to be my next guest because I changed out the vss before and that did not get rid of the problem.
Question- How or what would have caused the VSS to generate more voltages at higher frequency, thus causing the problem with the cluster?
While we're here, anyone have an ex 96-00 cluster 132k miles or lower for cheap?
Modified by m0nee at 10:46 PM 4/1/2008
Old 04-01-2008, 09:39 PM
OversteerMotorSports's Avatar
I got one. Hit me up... PM or email eatsleepjaydiem@aol.com
I will snap a pic if need be, but get at me.
Austin
vedha
09-02-2009 10:09 AM
m0nee
Honda Civic (2006 - 2015)
04-01-2008 07:05 PM
LS1powered
12-03-2006 02:00 PM
Phil Mac
10
04-16-2006 04:49 PM
sensorsearch
08-18-2004 04:52 PM
Quick Reply: Help - Speedometer Stuck on 15 mph
