can't pull codes
Re: (MasterShake)
what year is the car? have you tried to check the bulb in the cluster or even a code reader...autozone lets you borrwo them either obd1 or obd2 they have them for rent!! What method are you using to check your codes? https://honda-tech.com/zerothread/1901557
Re: (poppypizza)
I just went through this yesterday. If you have a cel find that jumper and use a wire or pin to do the 'pin trick.' THe cel will flash and tell you what codes you have. If you do the pin trick and the cel is solid (doesn't flash) then you have a connection/hardware issue. Check and make sure EVERYTHING is connected properly. As far as wiring the only thing that I can think of doing is tell you to search the pinouts for your ECU.
