need help ???????/
need help ???????/
ok i have a 99 ek hatch
i was told that if i swaped a 00 b16 w the wire harnes in to my car that my rpms wouldnt work and also v-tec wont ether
is this tru ?
is this tru ?
Re: need help ???????/ (ls-low-n-slow)
That's not true. If all the engine wire harness uncut and the speed sensor hooked up, they should be run perfect easily. V-tech should be engage but if there is problem with the V-tech solenoid, then the V-tech wont kick in.
Good luck for the swap.
Re: need help ???????/ (1999_ek9)
well i put it in and the spedo nor the rpms work
i was told that the dash harness is diferent ???????????
wisimports
24
02-22-2013 02:36 PM
