vx block with d16z6 head. timing belt help
hi my bottom end got mess up on my civic ex. so i got me a d15z1 block and i'm using the d16z6 head. as far as i now i have to use the d16z6 timing belt, i just want to comfirm that.
please help
please help
Re: vx block with d16z6 head. timing belt help (Biggmike92vx)
well looks like nobody knows what timing belt to use..............VX uses a small timing belt than the EX. i found out yesterday when i did my setup VX block EX head.
the point is not on the belt is on the tenssioner, VX has a smaller gap where the bolt goes so it has less space to adjust.
you can use any timing belt aslong as you use the same tenssioner
for example.
d16z6 belt with d16z6 tenssioner
d15z1 belt with d15z1 tenssioner..........all water pumps are 19 teeth..
for example.
Re: vx block with d16z6 head. timing belt help (argenis111)
Have you looked at what your compression is going to be with that head and block combo? http://www.c-speedracing.com/h...c.php
About 7.8:1 lol Idk how that's going to work out... you might do a little better if you used a d15b7 or an old d16a6... but unless you change those pistons your going to be running like
Contender25
12
09-12-2011 01:36 PM
eg6_trust
04-02-2011 02:36 PM
ssl2k
06-09-2005 12:02 PM
ssl2k
02-24-2005 11:16 AM
