alignment questions???????????
i need to do an alignment on my 92 hatch...i've heard that it helps out your handling if your rear tires are a couple negitive degree...how many degree do you guys recommend..note: this is my dd...thanks
Re: alignment questions??????????? (hard_boiled_EG)
My guess is the car drives best when within spec. I just had mine done last week. Paid $65 for it and handles great.
Re: alignment questions??????????? (nmhuntr)
Yea in theory negative camber will help a little bit with cornering but camber kits are overrated imo.
Have you recently lowered the car? I would just get an alignment and leave it at that.
Re: alignment questions??????????? (JDM Lyfestyle)
the cars been lower ever since i had the car...but i just recently installed my rear disc brakes...and after i was don't the driver rear had really bad positive camber...i know thats not normal for honda's usually it would be negative...so i installed my old camber kit...i might just keep it at 0 degree...thanks
the rear camber on these types of honda are supposed to be negative to factory spec. look at your alignment sheet to c where your rear camber is supposed to be. I belive it is supposed to be between -0.2 to -0.8 degrees if i am not mistaken
Andrew 825SM
08-15-2003 03:16 AM
rioninja
08-22-2001 02:21 PM
