2 Heads of Bolts Broken off..
Well since i bent my door i went to take it off and put the new one on...and broke off the rusted bolts that were holding the door to the car frame..and yea its BOTH of them..One of the bolts is slightly sticking out..and the other is broken off inside the hole...WELL i got the Drill-Out Extractor and all that was doing was making craters in the bolts and wasnt actually penetrating...But i managed to break the bottom bolt apart so half of the bolt is gone but the other half is still broken off inside the hole..What should i do?
Im sure there is a way to get them out..the top one is still sticking out..i couldnt get a drill into it because it was just making a crater in the bolt..so i just left it alone..but the bottom one the bolt extractor kinda broke the bolt into pieces and half of the bolt is still inside the hole...ANY OTHER OPINIONS?
Re: (bdubnyc)
a picture would help, but your not using those cheap scew extractors on tv are you?? the ones to get are irwins or craftsman, both are nice products, used both with great results, asside from trying to get the broken pieces back off the extractor when your done with it
Sorry it took so long..i kinda forgot i made this thread..here are some pics...i tried drilling the top one out but the crappy drill bit i was using just made a crater in the bolt as you can see...and the bottom one i managed to break it apart so half of the bolt is still in the hole...what should i do?
Re: (bdubnyc)
just keep drilling dude, make sure your drill bit doesnt screw up the threads and just keep on going till your all the way through then use a bigger and bigger until you can just scrape out whats left!
Re: (prettylew)
Drill the center of the bolt with the easy out? or drill a pilot hole then use the Easy out? Should i get the Spiral Easy out? will this get the job done?
Re: (bdubnyc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdubnyc »</TD></TR><TR><TD CLASS="quote">Drill the center of the bolt with the easy out? or drill a pilot hole then use the Easy out? Should i get the Spiral Easy out? will this get the job done?
should work
should work
Re: 2 Heads of Bolts Broken off.. (JoshuaVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoshuaVTEC »</TD></TR><TR><TD CLASS="quote">Use a dremel to make a slot or X in the top of each bolt, then use a screwdriver.</TD></TR></TABLE>
that will never work with a rusted bolt.
Re: (bdubnyc)
] </TD></TR></TABLE>
yes you drill a pilot hole. the easy out should have written on it what size drill bit to use. start with a real small one, then work your way up to whatever size it says on the easy out.
then you tap the easy out into the hole with a hammer. and SLOWLY turn the bolt out.
Re: (prettylew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdubnyc »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
need to get ma a set as well
civicservice
13
04-01-2018 05:39 AM
BoostinEJ1
41
04-16-2006 01:18 PM
BLUE EH3
13
06-06-2005 02:04 PM
CHiNkStEr
03-05-2005 07:35 AM
