will wheels fit gsr brakes????
Old 04-30-2008, 03:11 PM
cherroneballs's Avatar
Default will wheels fit gsr brakes????
Hi, evereyone, I have a 98 ek hatch with, 96 gsr brakes all the way around, will 96 civic hx 14" wheels fit over my calipers in the front, and work or not?
Old 04-30-2008, 04:00 PM
bump???
Old 04-30-2008, 04:02 PM
Global Moderator
Jimmy's Avatar
I don't believe the 14 inch HX wheels will clear the caliper unless you grind the caliper down.
Old 04-30-2008, 04:07 PM
pilot03's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">I don't believe the 14 inch HX wheels will clear the caliper unless you grind the caliper down.</TD></TR></TABLE>
x2
Old 04-30-2008, 04:14 PM
pdiggitydogg's Avatar
or you can just use 5mm wheel spacers...which is a better choice
Old 04-30-2008, 05:22 PM
pimpvw's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">or you can just use 5mm wheel spacers...which is a better choice</TD></TR></TABLE>x2
Old 04-30-2008, 07:05 PM
SoHcEK99's Avatar
Default Re: (pimpvw)
Everyone I know w/ HX's has grounded the calipers down.
Old 05-01-2008, 08:29 AM
This might sound dumb but I was looking at the spacers on ebay and was wondering if using a few washers (5mm thick) on each stud would be a safe option??? and do they carry the spacers in stock at like discount tire or is it something that would have to be ordered?
Old 05-01-2008, 09:09 AM
bump
Old 05-01-2008, 09:26 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Default Re: will wheels fit gsr brakes???? (cherroneballs)
no they will not. The spokes do not clear EX or GSR brakes.
Use a 5mm spacer. Use extended lugs. Use lug nuts from a 93-97 accord with aluminum wheels (the open ended ones).
More work than it's worth. Buy different wheels and sell yours.
Old 05-01-2008, 04:15 PM
You dont need extended studs with 5mm spacers.
No, washers are not going to work the same. You need a completely flat area, not flat "spaces".
Get the spacers....
JDMeg95
11-21-2007 08:10 PM
Dc2 Joe
01-13-2006 12:38 PM
fatmandc2
09-21-2005 03:28 PM
trunkszero28
03-17-2005 05:41 PM
euclid
04-22-2003 05:46 PM
Quick Reply: will wheels fit gsr brakes????
