95 civic jerks horribly under acceleration
my civic jerks horribly under accel at about 5% throttle the car feels as if your flooring it letting off multiple times. Its not the mounts i have new poly ones and Ive replaced the tps sensor and burped the cooling system. If you have the clutch in or if its in neutral and you hold it at 5 percent throttle it will rev between 1500 rpm and 2000 rpm up and down.
I also read through the how to on the check engine light and i can not locate the 2 prong plug so hopefully someone has had a similar problem.
car is a 95 lx sedan
Motor is d15b7 with a z6 head
Any help is greatly appreciated
MinimusMaximus
12
12-07-2016 10:33 AM
jtwarrior14
03-17-2015 12:40 PM
