Question about 99Civic EX - replaced distributor - check engine light
I had my distributor replaced yesterday. I have a 99 Civic Ex. Today when I drove it into work the check engine light came on. The mechanic is closed until Monday and now I am afraid to drive. Should I be concerned? Was there something they needed to reset or something when they replaced the distributor?
Thanks
Thanks
Re: Question about 99Civic EX - replaced distributor - check engine light (tdwidner)
You can drive, just take it easy. When it starts blinking, then stop driving. lol
Re: Question about 99Civic EX - replaced distributor - check engine light (Ice78transam)
Are you serious? I don't want to risk making things worse if I don't know why the light is on? I'm not trying to be difficult. But I really need a serious answer on this. I'm not seeing any humor in the issue.
go to autozone and theyll loan you a scanner, otherwise use the paper clip method to check your CEL.
Re: Question about 99Civic EX - replaced distributor - check engine light (ejprimo)
Just did the paper clip for the CEL
9 CYP - cylinder sensor is what I got. So I will take it to them on Monday to look at. I guess it will be safe to drive for now.
I was being serious. Your good to drive on a CEL, unless its blinking
I recently had the same code (9 CYP) showing up on my 98 Civic DX. I haven't done a tune up over 6 years so I did one - resetted the ECU to clear the code - 4 days later the light comes back on and with the same code.
According to the Haynes car repair manual, it suggested I should check the CYP sensor located in the distributor with a multi-meter but I'm having trouble disconnecting the electrical connector. Even pushing the release tab and trying to wedge the connector with a flat head screw driver wouldn't budge it? Any suggestions out there before I break the plastic casing?
y did you replace the dizzy in the first place, you can buy an igniter and coil seperatly
Stephen122193
01-02-2012 02:45 PM
