D16Y8 OBD2b ECU pinouts for the primary O2 sensor?
I believe my harness is messed up and I was wondering if anyone had or knew where to get the ECU pinouts for the primary O2 sensor....
-Grant
-Grant
http://technet.ff-squad.com/wiring.obd2b.htm
C1 & C16 are labeled on that. C18 should also be the ground for it. And the last wire is the Yellow/Black wire that is tied in with quite a few different sensors (like the injectors).
Re: (CivicSpoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSpoon »</TD></TR><TR><TD CLASS="quote">http://technet.ff-squad.com/wiring.obd2b.htm
C1 & C16 are labeled on that. C18 should also be the ground for it. And the last wire is the Yellow/Black wire that is tied in with quite a few different sensors (like the injectors).</TD></TR></TABLE>
You're my freakin' hero!!!
Hanmin
08-02-2008 11:33 AM
EX-T
12
05-24-2008 08:01 PM
