help here
help here
I was wondering on the 02 sensor end of it there is plug am I suppose take that out? also how would take out that plug from o2 sensor?
Re: help here (biggdogg)
This D16z6 motor. Um..my question is how do I take out plug it's from the 02 sensor from the long string plug?
[ ] ----------*02 sensor*
something like this ^
Re: help here (dorkjoey)
<U>I BELIEVE</U> what you want is to unplug the entire O2 sensor unit so you can remove it from the car. You follow the cord from the top of the O2 sensor itsself and it should lead into the floor board at some point. there is a *bung* there that just pops out that allows you to access the plastic connector. then just pinch and pull apart.
Re: help here (Ice78transam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ice78transam »</TD></TR><TR><TD CLASS="quote"><U>I BELIEVE</U> what you want is to unplug the entire O2 sensor unit so you can remove it from the car. You follow the cord from the top of the O2 sensor itsself and it should lead into the floor board at some point. there is a *bung* there that just pops out that allows you to access the plastic connector. then just pinch and pull apart. </TD></TR></TABLE>
how do I remove plastic connector freak won't come out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ice78transam »</TD></TR><TR><TD CLASS="quote">...then just pinch and pull apart. </TD></TR></TABLE> harder. break it if you must then tape it back together.
Re: (blk92_d16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk92_d16 »</TD></TR><TR><TD CLASS="quote">Flat head screwdriver. Put it inbetween the plastic ridges in the moldings and turn the handle. GL!</TD></TR></TABLE>
thanks guys for help.
Re: (dorkjoey)
On most of those plastic plugs there is a clip underneath that you have to push down on and then slide the plug off and then you can disconnect the o2.
Re: (Davus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Davus »</TD></TR><TR><TD CLASS="quote">Aha, I see you're going through with previous thread.
Yeah, plastic clip is sometimes a pain. Got the exhaust manifold heat shield off yet? :-)</TD></TR></TABLE>
yeah i did only problem is 02 sensor not coming out as it wants to. well...does anyone have an idea how I should take out 02 sensor? i use 7/8 tool bolt and racket won't come out.
Re: (dorkjoey)
dude hose it down with some penetrating oil of some kind and let it marinade 4 a few. go burn one or take a nap under the car. i have a o2 socket its huge u can get a deep well thats just deep enuff and take a grind wheel and slit the side of the socket so the connector and wire hang out.
Re: (dorkjoey)
big *** wrench?? just sack up and do it it's gonna suck but hit it with the pb blaster, let it sit and take the wrench to er, if grinding on the socket worries you, either get a cheapo one you don't care about and cut it or just get the O2 socket
Re: (Remington)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Remington »</TD></TR><TR><TD CLASS="quote">just sack up</TD></TR></TABLE>
itsrooster
15
08-24-2013 04:15 PM
