engine knocking
engine knocking
i don't know if it's the head or the block. when i start the car it makes a knocking like taping noise for like a second and at idle it sounds normal. but when i drive between like 2500 - 3200 rpm it makes the same noise and is quite after that till like 5000 rpm. but i didn't bring pass 5000rpm cause i don't want the motor to blow. i'm thinking if it's the rockers or i spun a bearing. what do you think?
GDD's Dr. Phil?
Re: engine knocking (DarikDisease)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarikDisease »</TD></TR><TR><TD CLASS="quote">probably the same way i did he took off the oil pan and checked </TD></TR></TABLE>
I bet not, I think he had someone listen to it and they told him... Nevertheless, most bearing problems that I have heard, come distinctly from the bottom of the motor, are too deep of a noise to be described as a tap, and usually do not go away with rpm (unless there is an oil issue)
h22apwrdcivic
06-08-2007 02:04 PM
MrEG6er21
14
03-24-2004 10:33 PM
