Jdm EG6 SiR Cluster?
is the jdm eg6 sir/vti cluster direct plug and play? or do i need to convert some wire harnesses? also does the Km/h run differently than the Mpg on the cluster?
Re: Jdm EG6 SiR Cluster? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">It's plug and play. It will read in KMH.</TD></TR></TABLE>
Re: Jdm EG6 SiR Cluster? (jdmstockeg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmstockeg6 »</TD></TR><TR><TD CLASS="quote">its the same with auto?</TD></TR></TABLE>
yes
yes
is there any way to dismantle the speedometers without touching the needles? becasue what i was planning on doing is, just swap the temp, and fuel gauges from the usdm to jdm , and removing the speedometer from my usdm cluster to the jdm one, but with the amber jdm arrow(whatever you call it). i want a jdm cluster that reads mpg will this work?
Seagull Management
It should work. The only reason I can't see it working is because the JDM cluster has a much lower top speed and everything is spaced out more (180KM/h vs 230KM/h) It will look like crap though.
Re: Jdm EG6 SiR Cluster? (94EG8)
yea what im worried about is, the cluster is jdm and having a usdm speedometer device inside that reads mph not sure if it will work, but its plug and play isnt it? so its compatible.
also how do i remove the amber arrow correctly?
Re: Jdm EG6 SiR Cluster? (turboteg90)
is there such as a kilometer to miles converter? like portable to install on the car? also can you hook up a 2 odometer readings. kilometes and miles on the car?
Modified by jdmstockeg6 at 6:18 PM 10/23/2008
Yes, there are KMH to MPH converters. They use them in the UK when they import gray market vehicles. It will make the speedo and odo in miles.
http://cgi.ebay.co.uk/HONDA-SP...0.m14
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmstockeg6 »</TD></TR><TR><TD CLASS="quote">how does that work?</TD></TR></TABLE>
You wire it between the VSS and your cluster I believe.
oh okay. is there such thing as a odometer gauge? becasue i want the miles and kilometers to be tracked the same time this possible?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmstockeg6 »</TD></TR><TR><TD CLASS="quote">oh okay. is there such thing as a odometer gauge? becasue i want the miles and kilometers to be tracked the same time this possible?</TD></TR></TABLE>
No
No
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmstockeg6 »</TD></TR><TR><TD CLASS="quote">any way to change the numbers without breaking anything? lol</TD></TR></TABLE>
On the odo? Yes, I've done it when switching back to the stock cluster when I was selling my car. Very time consuming.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmstockeg6 »</TD></TR><TR><TD CLASS="quote">all you did was turn it backwards riight? any other ways to do it?</TD></TR></TABLE>
I used a drill and a rod with a gear to turn it.
