Idle surge at 1500 in d15b
I just swapped a d15b into my 95 coupe and i have an idle surge at 1500 rpms, it goes from 1500 to 1600 so its not that bad but it sounds horrible. My cel is throwing a code 14 which is the iacv so i replaced it and no luck. Do you guys know anything else i can try to try and stop this. Thanks
Re: Idle surge at 1500 in d15b (almostjdmeg)
you got the purge vavle and iacv plugs hooked up wrong....or iat plug hooked wrong...had it happened to me switch the two plug and it went away just it burn a chip in my ecu......
