Does lowering a Civic affect gas mileage?
I've got a 98 Civic HX. I'm thinking about Tokico HP's to replace my OEM shocks and perhaps getting the Tokico springs which will lower the car a bit. Will the lowering affect gas mileage at all? I assume lowering the car will result in slightly better handling. What are the pros and cons of the lowering? Also, is tire longevity affected by lowering the car?
Modified by rhgindc at 7:06 AM 5/10/2008
Re: (batallic)
The only way I can see lowering affecting fuel economy is perhaps by making the car more aerodynamic at highway speeds, which would increase fuel mileage. That seems like a long shot, however. Tire wear will be unaffected as long as you get the car aligned after installing.
Re: (JohnnyWash1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnyWash1 »</TD></TR><TR><TD CLASS="quote">The only way I can see lowering affecting fuel economy is perhaps by making the car more aerodynamic at highway speeds, which would increase fuel mileage. That seems like a long shot, however. Tire wear will be unaffected as long as you get the car aligned after installing.</TD></TR></TABLE>
It's not a long shot. Lowering the car evenly gives you a small but significant gain in highway mpg.
Tokico HP is really bottom of the line and wont improve handling. I can understand that you're on a budget. But see if you can save up for at least the Eibach Pro-kit and some KYB GR2's. These will improve your handling for daily driving and not give you a harsh ride.
Re: (baller status)
If I remember correctly, the GR2s are not meant as performance shocks, just stock replacements. I've had great experience with Tokico HP, however. I wouldn't hesistate to use them again or recommend them.
Lowering a car will make the camber negative (the top of the tire will lean in) this will make the inside edges of the tire wear faster since they are now holding the cars weight. An alignment wont help because on Honda's you casn only set toe. I have seen aftermarket camber kits for lowered Hondas.
jimmy o.
15
05-16-2008 06:21 PM
inspireAZN
18
07-17-2007 02:56 PM
Cypher0117
10-13-2005 12:29 PM
eswaroop2
04-22-2004 11:01 AM
