93 civic stereo wiring
Old 05-10-2008, 10:49 PM
BiG_DeE's Avatar
Default 93 civic stereo wiring
my harness is cut, and i was wandering if anyone has a stock wiring list?? thanks!
Old 05-11-2008, 09:44 AM
jimmy o.'s Avatar
Default Re: 93 civic stereo wiring (BiG_DeE)
Just go find you a civic 86-98 with an uncut stereo harness and splice it in thats what I did to mine the other day. ive had to do this to 2 civic and threre pretty easy if this help remove the console that has the lighter and ashtray in it for access if your wires are too short. Also all the colors are the same just use a civic harness ive also been able to use a teg harness in my old EG
Old 05-11-2008, 03:12 PM
edfed's Avatar
Hey brother, i just did this to my car- what i ended up doing was looking at the wires that go to each of the speakers- they led all the way back to the head-unit, so that's how i knew what was what. Hope this helps!!
Old 05-11-2008, 05:34 PM
suno's Avatar
Constant 12V+ Blue/White
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Driver's Pillar
Front Speakers 6 1/2" Doors
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Old 05-27-2008, 10:14 AM
The_Wizard's Avatar
Default Re: (suno)
Check sig...e-mial me if need be.
Modified by The_Wizard at 11:21 AM 5/27/2008
Old 05-28-2008, 02:49 AM
mike032005's Avatar
1993 Honda Civic Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Blue/White
Car Radio Switched 12V+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Radio Dimmer Wire: N/A
Car Radio Power Antenna Trigger Wire: N/A
Car Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2″
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2″
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Old 05-28-2008, 10:37 PM
TeamRPM_ZC's Avatar
Default Re: 93 civic stereo wiring (mike032005)
thanks i needed that too
Old 05-29-2008, 03:55 PM
itsmejto's Avatar
I believe Honda radio wires have their designation printed on the wire itself, look with a magnifier, it's small print, like an asprin bottle instructions
Old 06-01-2009, 02:14 PM
sk8kingda3rd's Avatar
Ok so im new here and I just got my first honda civic last week. Its a 93 coupe EX. The wiring harness was cut and I was using the diagram to wire up my new deck and it was working perfectly until i hooked up the right front speaker. When I hook it up all the other speakers make no noise and I get a buzzing from the right front. Any ideas?
Old 06-01-2009, 03:50 PM
thumper64's Avatar
Short somewhere?
Screw it, ditch the stock wiring and run your speakers off an amp. A lower amperage 4 channel isn't that expensive.
Old 08-24-2009, 08:58 PM
S_K_C's Avatar
ok this might be stupid but my constant in my car is white/blue instead of blue/white does that matter? because i hooked up my ground switch and constant and the head unit is not working....i cant figure it out my fuse works fine cause my cig lighter and clock both work but my constant and switch both dont have power...can someone help me
Old 08-24-2009, 09:14 PM
thumper64's Avatar
Get a multimeter and test the wires. It's odd to have both a bad constant and switch. Did someone hack up your harness? If it's really screwed up, you can find another harness or run the constant to your underhood fuse box (closer to the battery, better quality power) and the switch to the under dash fuse box where fogs would hook up.
The radio and clock aren't on the same circuit. Check your fuses, do the job right, don't hack it up like a 16 year old who thinks they are a pro at wiring and run random wires all over.
Old 08-24-2009, 11:10 PM
S_K_C's Avatar
o ok well i didnt do it by mysalf my dad helped and he has done this kinda of stuff plenty of times. we hooked up the ground, switch and constant up according to the directions on the harness. but in not sure witch one it bad or if its bad at all. but so basicaly im not getting enough power from my constant?
Old 04-08-2010, 06:10 PM
scrubbysteve's Avatar
K im a scrub at this too. Anyone mind helping me? I just got my 93 civic coupe dx and both power wires to the radio are melted. The red and yellow and blue and white. Just take is i need a harness for the junk yard??
Old 11-22-2010, 11:31 AM
latchkey's Avatar
Hey guys i just installed a new stereo. everythings connected accordingly but it won't power on. what could it be. help is highly appreciated thanks
Old 11-28-2010, 04:34 PM
meric0786's Avatar
What gauge wire is the steels harness 10 and 18
Old 11-30-2010, 04:20 PM
meric0786's Avatar
Thank guys really headed that list helped tremendously
Old 11-30-2010, 05:51 PM
Former User's Avatar
Check the fuses.
Old 04-02-2011, 09:59 AM
apositano's Avatar
Icon3 Re: 93 civic stereo wiring
Ok everyone, so I just did this little wiring job for the first time since I get my stereo stolen every other day lol...The wiring harness diagram below is correct for my 1994 Honda Civic, However the Car Radio Constant 12v+ wire is NOT Blue/White, it is White/Blue...not a big deal if you hook up all the other wires it is the only one left lol...buuuuut my problem was that the constant wasn't putting of 12 volts, while my switched 12V+ was. Here is the deal, the constant is meant to supply constant 12 volts to the stereo, so that when you turn the thing off, it doesn't reset itself. I had hooked everything up the right way and I was getting 0 power. So, I took a voltage meter and measured the voltage from the wires...with the constant I was getting about 2-4 volts with the car off, and the switched was giving like 13-14 volts...problem is, which a lot of you might be having, the constant isn't putting off enough power, so if you wire the wire coming from the stereo that is supposed to be for the constant as well as the wire from the stereo that is supposed to be for the switched, to the wire coming from your car that has 12 volts or more, in this case mine was the switched not the constant, then you should get power. However, since there is not constant voltage the stereo will reset itself to factory defaults every time you turn the car off. I am not sure how to get around this at the moment, but at least I have power to my radio. so again, the wires coming from the stereo that you have, should be 2 of them one meant to be to the switched and one to the constant, both attached to what wire you have voltage from coming from your car(get a volt meter and check the voltage, radioshack has them)....hope this helps
Car Radio Constant 12V+ Wire: Blue/White NOT Blue/White...It is White/Blue
Old 04-17-2011, 08:46 PM
RoarCivic's Avatar
I have the same problem as apositano.. my new XD1225 stereo won't turn on on my 93 civic.
with my voltmeter i get 12V+ from the red switched wire but only 3-4 from the yellow / constant wire.
Ive checked both the car's fuse for stereo and the fuse on the yellow/memory/constant wire. they new.
voltage is 12V at the battery terminals..
need help please where/ what can i check..
thanks for your time
Old 04-18-2011, 02:56 AM
The Grumpiest
grumblemarc's Avatar
Get a real wiring harness if you don't have one. Make sure you are grounded properly.
Old 04-23-2011, 03:04 PM
daver's Avatar
i'm getting the same problem on my '94 civic all of a sudden. The 12v constant wire going to the radio is only putting down only 2-4v, so the radio won't turn on. Did you find an answer yet? It worked fine until i replaced a blown ignition coil this week. i'm wondering if i jimmied some wires somewhere during my troublshooting
KILLAB17VTEC
Audio / Security / Video
10-03-2010 02:36 PM
ClutchVtech9
10-13-2008 09:45 AM
Hoffy
09-20-2006 10:58 AM
DoctorGSR
09-02-2004 01:36 PM
AzntaggeR
04-10-2003 08:12 AM
Quick Reply: 93 civic stereo wiring
