Having Engine Problem with my delsol
ok i have a 94 sol with a d16z6 & every time i started for the first time in the day it fires right up but after i drive to where ever im going to, when i shut it off and dont let it cool off it struggles to start right up unless i give it a lil gas it will start up. what could be the problem the CEL isnt on so i cant troubleshoot it. Has anyone experienced this issue????
Re: Having Engine Problem with my delsol (twr176)
whens the last time you had an ol' tune up? i.e. plugs wires cap fuel filter air filter oil filter blah blah
two things... could be the master relay, or the fuel pump relay....i used to have the similar problem and i change both at the same time.. and guess what.. it works.!!
Re: Having Engine Problem with my delsol (JdelMsolG)
1month ago replaced distributer,plugs,timing belt,water pump,oil,flushed rad. can da problem be da fuel filter?
Wow, story of my life..
I'm having the same issue, it cant be the fuel filter because I changed mines out and I'm still having that problem.
Trying changing your fuel pump and check your compression like what Hanmin said.
And also check your Main Relay, I changed mines out and it's giving me a little better response.
Re: Having Engine Problem with my delsol (carboncivic94)
damm head gasket huh .
i'll do a compression test and from there but i was hoping it would be something smaller.
bignosewhipper
16
07-03-2008 05:38 PM
