front end question?
front end question?
I just got into an accident last tuesday.. I got all my cosmetic taken care of, but im stuck on why my drivers side tire is sitting 2-4 inches back.. I replaced the axle and lower control arm.. any ideas?? heres the pic.
Is there any frame damage?
Did you check around the axles to see if anything looked out of place or bent?
If it was pushed back a few inches then something isn't aligned right..
Check again and look into the littlest detail.
Re: front end question? (DeaDPooL)
Did you get the whole control arm or just the back portion? It looks like the front part, the straight peice that connects to the hub might be bent. Because to me it looks like your shock is tilted forward which would coincide with a bent arm. also you tie rod needs to be changed.
Re: front end question? (alphalanos)
i haven't changed anything as of yet. I was looking at some things today and took the pics. when i took the tie rod off, I could not get it aligned back up straight with out putting like it was.
92integraVTECgsr
12-10-2012 03:27 PM
patastinky
03-24-2003 02:21 PM
dan89crxsi
01-06-2003 11:03 PM
