Can anyone please help with this..
Guest
Posts: n/a
https://honda-tech.com/zerothread?id=2333581
F...u....c....k the lot of you....
Iv'e asked about this time n time again, but no one can/will answer.....maybe you dont know, but you could have at least have said.
Now I'm getting a msg when posting to say that I cant post more then 5 in 24 hr's.....what the *** kinda site is this....apart from sh1te....
Modified by memyselfnme at 8:57 AM 7/1/2008
Modified by memyselfnme at 8:58 AM 7/1/2008
Re: Can anyone please help with this.. (memyselfnme)
your getting thta message cause your so new it will go away once the site sees you going to be a good addition to the site and not some one who will just run there mouth its common on forum websites.
as for your tranny issue sound like its low but kinda need more info did it just start happening or did you just put it in or make any recent changes
a jerky shift can occur from several things. my fiancée's toyota has a jerky shift cause i need to change her oil. i know that already and am doing it later today. this old oil has made her check engine light come on though and it only jerks when the light is on. again, i already know the source. the engine is trying to intentionally slow itself down because of bad lubrication. thus creating a jerky shift.
my problem here is that on her car it is jerky on 1-2 and 2-3. which it should be under the circumstances. your car is jerky into 4th leading me to believe it needs automatic trans fluid or a new transmission altogether. i would go to a transmission shop after i got an oil change if the problem kept going. only reason for the shop is due to i do not mess with automatics. too many parts involved. otherwise it is much more complex than a standard shift. let us know how it goes.
