ek hatch starting problem
well the problem is the car will turnover and it has spark but it has no fuel. I loosend the main fuel line on the filter and nothing come out its dry. The main relay is working cause i here it clicking on and off, and the CEL goes off also. I also ran a wire from the positive side off the battery str8 to the yellow/grn wire on the fuel pump harness under the rear seat and nothing. Then i replaced the pump with a walbaro and still no juice. the pump is getting power
The car was originally auto but i converted it to stick, and wired the shifter assembly to think its in park but the cluster says its in gear #2 but i can still get my key out, could that be the problem? Thanks in advance!
Modified by japspecb7 at 8:05 PM 7/1/2008
Modified by japspecb7 at 12:37 PM 7/2/2008
Theres a little trick at least on the eg chassis. At the main relay, unplug it and use the paper clip and jump two prongs on the connector, it runs power straight to the pump, look in your helms manual if you have one. Check your grounds too.
EK9 B16B TSL
01-15-2005 12:16 PM
