Camber arm hitting Shock tower and going through engine bay?
so i have a H22 Civic Eg hatch. Koni yellow sports with Eibach Sportlines. Some How my camber arms on the front put a hole on each side in the engine bay. I will get pictures. I have no idea or have seen this happen before. Does anyone know what it could be. Blow shocks? springs can hold the weight of H22 swap? some HOW it is smacking and put 2 holes....
Re: Camber arm hitting Shock tower and going through engine bay? (Silvertc)
Even though the H22 is not too much heavier its possible its pushing down enough. Does your car bounce at all? Too low? you might need too stiffen the front or raise your ride height.
Re: Camber arm hitting Shock tower and going through engine bay? (alphalanos)
to be honested its dumped as F***, no it doesnt bounce, i avoid any bumps/pot holes ETC. But when it does hit a small bump it sounds like its really stiff as **** and its def the Camber Arms smacking....im think its either to low? because ya that H22 is a little bit heavier, but shouldn't affect to make it that low to hit. I'm pretty sure shocks aren't blown, i've driven in car with blown shocks so idk...
Modified by Silvertc at 6:56 AM 7/1/2008
Silvertc
Suspension & Brakes
07-01-2008 01:41 PM
93preludeh22
02-17-2006 04:39 AM
OneZero1010101
05-29-2004 03:51 AM
Kamikaze-Kart
03-04-2003 02:36 PM
