idle/leak problem help!!!
okay so i own a 92 hatch with a d16z6 swap. my problem is that since i change my throttle body it idle from 2.5-3 rpm back and forth. if i open the throttle body a little bit it rev the motor all the way to redline and wont stop until i turn off the car. But if i cover the throttle body with my hands it goes back to normal, so i have a leak somewhere right? i never had that problem until i change the throttle body. i also change the gasket too! tighten every bolt tight and plug all the line in. please help vacuum line is plug in.
