TRANNY FLIUD
318 Curves, 11 miles
Re: TRANNY FLIUD (turboy7)
For a manual transmission, there's a filler bolt halfway up the passenger (I think) side of the transmission with a 3/8" squarehead. Take the bolt out and stick your pinky in. If you can feel fluid, it's right, assuming the car is on level ground. You'll have to do this from underneath the car.
Its a 17mm filler bolt, the 3/8 is the drain bolt.
The dipstick for automatics is right below the radiator fan. It should be yellow in color.
Re: TRANNY FLIUD (slowcivic2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k »</TD></TR><TR><TD CLASS="quote">Its a 17mm filler bolt, the 3/8 is the drain bolt.
The dipstick for automatics is right below the radiator fan. It should be yellow in color.</TD></TR></TABLE>
yep take the 17 mm out if fluid comes out u are good and if not add some make sure u park on level ground
Re: TRANNY FLIUD (b18 hatch mike)
well i cant check it sittin on the ground cause it is so low but if i jack it up and put jack stand under both sides so its still level its ok right
i-VTEC_DOHC
Honda Civic (2001 - 2005)
05-31-2012 03:48 PM
aphex23
37
07-12-2004 02:33 PM
