5th Gen Civic Auto to Manual Starting Circuit, The Right Way - Honda-Tech - Honda Forum Discussion
Old 07-21-2008, 04:11 PM
Seagull Management
94EG8's Avatar
Default 5th Gen Civic Auto to Manual Starting Circuit, The Right Way
Ok, i've seen a ton of auto to manual swap threads on here, for years, way before i was ever a member, and most of the swap is very well documented. There is however one glaring omission, the starting circuit. Every swap guide i've ever seen said either just join to 2 large wires together or extend the 2 wires from the there to the clutch pedal switch. they both work, kinda. Method 1 works, but you wont have a saftey switch so you can start the car with the clutch out and in gear, not so safe. Method 2 i don't like because people run 22 gauge wire from what starts out as about 10 gauge, this is why honda used a relay, in theory that speaker wire could get hot and burn from that excess current if you held the starter on long enough, also not so safe. So i've decieded to do a mini write up with pics. Manual civics use a clutch relay, its bolted to the inside of the car up above the hood release, you will need this, follow the wires there will be a small blue wire that goes to the yellow plug that goes to the clutch switch, (there is a black ground coming from this plug, cut it off about a foot away from the plug and ground it in the automatic vehicle), and 3 large wires, 2 black/red and 1 black white, follow the 3 large wires to where they go into their 3 respective plugs, depin them from these plugs. find the respective plugs on the automatic vehicle, depin the wires that are currently there and pin in the ones from the clutch relay. plug your yellow plug into the switch of the clutch pedal, thats it. here are some pics to try to make it a easier to understand.
Component Locations
To Clutch Relay
From Clutch Relay
To Ignition Switch
If anyone has any questions or comments feel free to post here or PM me. If I haven't explained this well please let me know.
Edit, thought i'd add this, its a pic of the clutch relay with all wires depined from vehicle harness, thought it might help make this make more sense.
Modified by 94EG8 at 5:31 PM 7/21/2008
94EG8 is offline
Old 07-21-2008, 04:51 PM
Luserkid's Avatar
Very nice
Luserkid is offline
Old 07-21-2008, 05:21 PM
Seagull Management
94EG8's Avatar
Default Re: (Luserkid)
Thanks Luserkid, that means a lot coming from the guy who did the 6th gen auto to manual swap guide.
94EG8 is offline
Old 07-25-2008, 08:09 AM
Loserkidwac's Avatar
Default Re: (94EG8)
I should be doing this over the weekend, thanks for the great info!
Loserkidwac is offline
Old 07-25-2008, 10:18 AM
Seagull Management
94EG8's Avatar
Default Re: (Loserkidwac)
Let me know how your swap goes, i'd like to know if my write up was clear enough to follow. Forgot to add remove the blue shift interlock relay that goes where the clutch pedal should be. Good luck on your swap.
94EG8 is offline
Old 07-27-2008, 02:36 PM
Default Re: (94EG8)
Just completed swapping in the relay and wiring up my second clutch sensor to the ECU for my VX swap, worked great...feel a lot safer knowing there is a relay there and not chancing burning up the wires! Other then me not using a good ground at first this was very easy to do! Thanks for the info!
Old 07-27-2008, 04:24 PM
Seagull Management
94EG8's Avatar
Your welcome, i appriciate the feedback.
94EG8 is offline
Old 10-26-2008, 07:44 PM
EK TUNER's Avatar
Default Re: 5th Gen Civic Auto to Manual Starting Circuit, The Right Way (94EG8)
I'm doing an auto to manual swap soon and I wanted to add this clutch relay to my car... but with a twist. I wanted to know if I could rewire the relay so that I could use a different switch to activate the relay instead of the clutch-activated switch. I was thinking of using an some OEM switch, like cruise control(my car is a DX so it doesn't have cruise control) so that it functions as sort of kill switch. Is this possible.
EK TUNER is offline
Old 10-27-2008, 06:50 PM
Seagull Management
94EG8's Avatar
Default Re: 5th Gen Civic Auto to Manual Starting Circuit, The Right Way (EK TUNER)
you can definately wire up a different switch than stock.
94EG8 is offline
Old 10-31-2008, 09:09 PM
EK TUNER's Avatar
Care to explain how? I've never done any wiring with relays and such so I'd appreciate it if you could...
Modified by EK TUNER at 10:59 PM 10/31/2008
EK TUNER is offline
Old 11-01-2008, 06:31 AM
Seagull Management
94EG8's Avatar
so long as you add the relay take the two wire going to the yellow plug going to actual clutch switch (blue and black wires) and run them to a switch, thats pretty much all there is to it. the clutch switch is normally open and closes when the clutch is depressed, simply use another switch the operates in the same manner.
94EG8 is offline
Old 02-27-2010, 01:20 PM
Oh look, I can change this
deschlong's Avatar
Any chance you can re-host the picture files, 94EG8? Not that I'm planning on doing this, but as a service to everyone who will refer to this post in future.
deschlong is offline
Old 02-27-2010, 05:37 PM
Seagull Management
94EG8's Avatar
Pics fixed. Just had to login to my photobucket account. Thats for DeSchlong for bringing it to my attention.
94EG8 is offline
Old 03-12-2010, 10:42 AM
9db85's Avatar
94EG8, I used your way to do my auto to manual swap about a year ago. It has worked great. Thanks for the write up. The thing is I have never hooked up my reverse lights, How do you go about doing this? There are many other threads on how to do this but they are not using the clutch relay.
9db85 is offline
Old 07-04-2010, 01:57 PM
Seagull Management
94EG8's Avatar
I hadn't noticed this post till now, but for future refernce I ran mine off the automatic shifter plug and out through the firewall to the transmission.
94EG8 is offline
Old 06-05-2011, 11:46 PM
I need to do this, subscribed for when I have time.
lordhelmet1584 is offline
Old 10-16-2011, 08:40 AM
95Sol99civic's Avatar
I have a question. What about for my 97 civic? Im adding cruise control also if you happen to know about that also.
95Sol99civic is offline
Old 03-20-2014, 10:39 PM
I bought a b16 engine and 5 speed tranny to swap out my d15 with auto. In my 1990 civic DX. List of parts to get for the auto to manual swap if you could please!. Much needed help
whiteboy1211 is offline
94EG8
General Discussion and Debate
15
01-28-2014 06:16 PM
94EG8
10-06-2013 11:15 AM
94EG8
10
09-04-2013 01:50 PM
94EG8
Transmission & Drivetrain
10
04-04-2013 11:33 PM
94EG8
11
09-13-2010 07:56 PM
  • Ask a Question
Question Title:
Description:
