Speedo and tach not working in del sol
Speedo and tach not working in del sol, is there a common ground for these? No cel.... odometer dont work, gauge lights work, coolant temp and fuel gauge work.... any thoughts?
Re: (blk92_d16)
VSS is connected and there is no fuse for just speedo and the tach its the whole cluster..... is it possable that the cluster is bad?
Re: (Dramysx)
the car runs.. ill check the fuse agian in the mornin.. but every time i have seen that blow.. the tach still works unless this car happens to have two seperate issues....
Re: Speedo and tach not working in del sol (sto4gcivic)
Hi
I got the same problem,
car runs just fine...
The CEL, indicators, oil , speedo , revs dont work on the dash...
The dash background light comes on..the fuel and temp work
But rest doesnt...does any know what i should do to fix this???
replace blown fuse driver side fuse block on my del sol its top row in the middle was a 10 amp on mine double check your fuse block fuse by fuse it can be a bitch but chances are thats it
DSolBuccFann
10-21-2013 08:30 PM
delsoldriver96
10
07-31-2013 09:38 AM
AzntaggeR
04-14-2003 12:01 AM
